Hourglass energy problems in AUTODYN Explicit Dynamics in projectile impact simulations
    • bobsik641
      Hello everyone!
      I'm doing two simulations in the Explicit Dynamics module. Regarding the solver output, both Momentum Summary and Energy Conservation (energy error=0) are fine. However, there is some Hourglass energy,  which exceeds the conventional 5% of the Internal Energy. How can it be solved in these cases?
      Projectile impact: erosion on material failure, materials: two different explicit structural steels, but the same erosion criteria (Max Principal  Strain=0.3,Max Shear Strain=0.5). Only a 90deg slice is analysed, proper symmetry conditions imposed.
      Cylinder impact: erosion on material failure, materials: cylinder- explicit steel (Max Eq Plastic Strain=0.2), disk- explicit AL (Max Eq Plastic Strain=0.4). Only a 90deg slice is analysed, proper symmetry conditions imposed.
       EDIT: I reduced the target plate size and then refined the mesh on both features, but it didn't resolve the issue
    • bobsik641
       I cannot attach nor JPG, nor PNG screenshots, so you can access everything here
      https://docs.google.com/document/d/1Ry3i25JkLQWjQfqkkaBd5buiKVSLpGJjBdsuOSZeagI/edit?usp=sharing
    • bobsik641
      bump
    • Wenlong
      You may have already tried this, but just checking: have you tried changing the hourglass damping control to "Flanagan Belytschko"?
      Wenlong
    • bobsik641
      Thank you, I really appreciate your help. Flanagan-Belytschenko did some fantastic work. The hourglass energy was vastly reduced. I used a stiffness coefficient of 0.03 (as suggested by  a LS-DYNA manual) so as not to add excessive stiffness to the model.
      That hourglass damping control had once spoiled my solution, so I didn't even think about using it.
Viewing 4 reply threads
  • The topic ‘Hourglass energy problems in AUTODYN Explicit Dynamics in projectile impact simulations’ is closed to new replies.
