November 12, 2024 at 6:10 pm
Energizer
SubscriberHello everyone.
I try to simulate bullet impact on reinforcement concrete slab, but fail. Bullet just passing through slab and left small damage. I use CONTACT_ERODING_SURFACE_TO_SURFACE between the projectile and concrete. Slab material is MAT_CSCM_CONCRETE, reinforcement MAT_PLASTIC_KINEMATIC.
Without reinforcment all good, slab desroyed under shock.
What do I wrong?
November 25, 2024 at 10:24 am
Erik Kostson
Ansys EmployeeAnsys employees cannot comment on this - perhaps other forum member can chime in here and advice.
Erik
April 20, 2025 at 4:39 pm
ilker.kurtoglu
SubscriberHi,
You can reduce your timestep and reduce BSORT cycle for a better contact detection. Moreover, you can use erdoing_nodes_2_surface contact being the concrete slab as the surface and penetrator as the node set part.
If you are using SOFT=2 option, read the manual carefully for correct settings of SBOPT and DEPTH parameters.
Good luck.
İlker Kurtoğlu
April 20, 2025 at 4:48 pm
Energizer
SubscriberÂ
Thank you for your advice.
4152
1487
1318
1170
