August 15, 2024 at 10:33 am
abbas.al-lami
SubscriberI was using 2024R1 without any noticeable problems, but after switching to 2024R2, I encountered an issue with an unusually high temperature value for the surface. The error message reads: 'The maximum temperature (3000°C) for this simulation is very high. Check the model setup'. The temperature value should be around 60°C. I tried resetting the setup, but nothing changed.
August 16, 2024 at 7:53 am
NickFL
Subscriber- Is it just for a couple of iterations and it goes away? Or does it persist throughout the solution?
- If you have an old saved solution, and using that for an initial condition, continue to solve and see if you get the message.
- Double and triple check all your boundary conditions. Are all the surfaces assigned the correct conditions?
August 16, 2024 at 9:13 am
abbas.al-lami
SubscriberIt is shown in the final results. I have carefully checked the BCs. I havent faced this issue in persious versions and these issue appeared at different simulations with different CFD domains. As you see below, the max. temperate should be not exceed a 61C because we dont have a heat source in the system.
August 16, 2024 at 9:29 am
NickFL
SubscriberAre there large areas that are showing these extreme temperatures (there is also -181°C region)? Or is it simply a couple of cells? What is the mesh quality in these regions?
I am not exactly sure what your problem is, can you simulate it as isothermal? And then turn on the energy equation after the solution is mostly converged.Â
August 16, 2024 at 12:55 pm
abbas.al-lami
SubscriberÂ
It seems becuase of rotation boundary condition. When I remove the rotation condition, the temperature looks relastic. But why😬?
August 20, 2024 at 9:23 am
Forum ModeratorWith a rotation speed of 6500 rpm what sort of tip velocity are you getting? Have you then resolved the flow in those regions: Nick's comment re the effected areas is also something to check. A monitor and warning isn't overly useful when diagnosing solution issues.Â
5734
