May 5, 2020 at 9:47 am
jindrich.hala
SubscriberHi, I am struggling with the generation of the contour plot from the batch 2D computation running on a cluster using FLUENT 19.3. I could not find the way to hide the mesh outlines which always display on top of the contours I want to display on the clipped surface even when I use /display/set/contours/render-mesh no TUI command. I can get rid of it in GUI but I would like to make it via TUI.
The relevant part of the journal file code I am using is:
/display/set-window 2
/display/set/render-mesh no
/display/set/contours/surfaces iso-xy ()
/display/set/contours/filled-contours yes
/display/contour/mach-number 0 1.8
Thank you for any advice!
May 5, 2020 at 11:10 am
Forum ModeratorUse the new (at 2019) objects then you can choose to show just contours, contours + mesh etc.
May 5, 2020 at 1:07 pm
jindrich.hala
SubscriberHi, thank you for the reply, but it seems it does not make what I need. In the object menu there are only entities which appear under the graphics or plots section of the Outline View if there are any defined. The problem is that I want to define all the stuff which display in the current window using the TUI but it is somewhat tricky to get rid of those lines.
May 6, 2020 at 2:48 am
Keyur Kanade
Ansys Employeei am not sure which are these lines.
are these lines from mesh?
please try commands under /display
please check surface-edge-visibility
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
May 11, 2020 at 10:48 am
jindrich.hala
SubscriberHi, yes these are lines from mesh.
I solved it finally by selecting /display/update-scene/select-geometry, selecting unwanted geometry and then applying /display/update-scene/display no.
- The topic ‘Hide mesh outline in FLUENT contour plots via TUI’ is closed to new replies.
6600
1311
