March 7, 2019 at 5:59 pm
heechangna
SubscriberWe tried to run HFSS jobs with 28 cores by
/usr/local/ansys/18.1/v181/AnsysEM/AnsysEM18.1/Linux64/ansysedt -distributed -ng -batchoptions "HFSS/HPCLicenseType=Pool" -machinelist num=28 -batchsolve TEST_Simple.aedt
We used "HFSS/HPCLicenseType=Pool" because we know that we have hfsshpc, but not hfsshpc_pack.
But, we got the errors as following:
[error] Project:TEST_Simple, Design:2D_new_no_66mohms (Transient, XY), Failed to check out license 'hfsshpc_pack'
The question is how we can run the job using 'hfsshpc' instead of 'hfsshpc_pack'?
Thank you so much!
-Heechang
March 11, 2019 at 2:53 pm
ANSYS_MMadore
Forum ModeratorHello Heechang,
Can you modify the command to use:
/usr/local/ansys/18.1/v181/AnsysEM/AnsysEM18.1/Linux64/ansysedt -distributed -ng -batchoptions " 'HFSS/HPCLicenseType'='pool' " -machinelist num=28 -batchsolve TEST_Simple.aedt
Thank you,
Matt -
March 11, 2019 at 4:40 pm
heechangna
SubscriberHi Matt,
Thank you for the suggestion. But, it gives the same errors.
[error] Project:TEST_Simple, Design:2D_new_no_66mohms (Transient, XY), Failed to check out license 'hfsshpc_pack'.
License server does not support this license (FLEXlm Error -18) -- Simulating on machine: o0202 (12
0
4 PM Mar 11, 2019)
[error] Project:TEST_Simple, Design:2D_new_no_66mohms (Transient, XY), Simulation was terminated by license error. (12
0
4 PM Mar 11, 2019)
Stopping Batch Run: 12
0
5 PM Mar 11, 2019
And, it is working just fine with one core.
Please let me know if you need any other information.
Thanks.
-Heechang
March 11, 2019 at 5:00 pm
ANSYS_MMadore
Forum ModeratorIs this an HFSS project? Please make sure to use the proper project type for the batch options. Also modify the order of the command.
/usr/local/ansys/18.1/v181/AnsysEM/AnsysEM18.1/Linux64/ansysedt -distributed -machinelist num=28 -ng -batchoptions " 'HFSS/HPCLicenseType'='pool' " -batchsolve TEST_Simple.aedt
'HFSS 3D Layout Design/HPCLicenseType'='Pool'
'HFSS-IE/HPCLicenseType'='Pool'
'HFSS/HPCLicenseType'='Pool'
'Maxwell 2D/HPCLicenseType'='Pool'
'Maxwell 3D/HPCLicenseType'='Pool'
'Q3D Extractor/HPCLicenseType'='Pool'
Thank you,
Matt
March 12, 2019 at 5:57 pm
heechangna
SubscriberHi Matt,
Thank you so much! It worked with 'Maxwell 2D/HPCLicenseType'='Pool'.
This solves the issue.
Thanks, again.
-Heechang
- The topic ‘hfsshpc vs hfsshpc_pack license’ is closed to new replies.
5849
