May 19, 2024 at 3:19 am
Hari MK
SubscriberI have attached a screenshot of my simulation here. I am performing a parametric sweep. However, when I perform the same parametric sweep when i set he dielecric property of the brick, the simulation pauses at the current step. It works fine when I set the material to be PEC. The parametric beam sweeps from -1000mm to 1000mm in 40mm increments. The excitation frequency is 77Ghz to 80Ghz with 7.5Mhz increcements.
Things I have doneÂ
1) I have increased the number of cores under HPC optionsÂ
2) I have reduced the complexity of the mesh ( from 6000 faces -> 1000 faces )
What are some things I can do to ensure the simulation completes?Â
May 27, 2024 at 4:34 pm
Aymen Mzoughi
Ansys EmployeeYou can use GPU computing to accelerate SBR+ simulations
- The topic ‘HFSS SBR+ Simulation’ is closed to new replies.
5794
