December 6, 2024 at 8:26 am
kagankarakusx
SubscriberHello, I want to create a rotating table for radiated emissions in hfss. DUT will be on the platform and will rotate circularly, which function can I use to do this? Is there an example?
December 17, 2024 at 10:07 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
You can use rotate command available in the Draw tab ribbon area. Define the rotate command interms a variable to do a parametric analysis. You can group the objects that rotate along with the platform before performing the rotate command for ease of use.Â
You can go through - Coax Bend model available under Open examples > HFSS > RF Microwave on how to use the rotate command.
Best regards,
Praneeth.
1890
1419
1304
