Electronics
Electronics
HFSS Floquet port
    • Zhong-Min (John) Liu
      I cannot selec the HFSS Floquet port, it is grey.  I followed two youtube videos and I have the same problem. Why that? License problem?
      John
    • Chinmay Telkikar
      Which solution type you are using for the simulation?
      To assign the floquet port you need to use "Modal Network" solution type.
      Thank you,
      Chinmay
      Hi Chinmay,
      Thanks it works.
      John
  • The topic ‘HFSS Floquet port’ is closed to new replies.
