Electronics
Electronics
HFSS Animation
    • John Doe
      When I create an animation with "Swept Variable"="phase" it seems I am limited in stepsize. E.g., if I try start=0deg, end=350deg, steps=1 it keeps reverting to steps=35. I can't find where this limitation is documented.
    • AncS
      Hello John,
      The 'Steps' option in the 'Modify Animation Setup' window provides you the total number of steps of the phase you want in animation and not the step size. If you want 350 steps of phase in your animation with a span of 1 degree then put:
      Start: 0 degree
      Stop: 350 degree
      Steps: 350
      Hope this may help!
      Regards
      Anchal
  • The topic ‘HFSS Animation’ is closed to new replies.
