Materials
Materials
Topics related to Granta Design and more.
Help with Steady State Thermal Analysis
    • mc77
      Hi! I have some questions about setting up the boundary conditions for steady state thermal analysis. I am modeling a copper cylinder at 250 C radiating to a heat flux gauge (which I model as a small stainless steel disk).
      Can I define two boundary conditions on one surface?
      Should I define temperature across the entire cylinder and then have it also radiating surface to surface with the disk, or should I only define temperature on the top half of the cylinder?
      On the top half, can I have convection, radiation and temperature as conditions?
      Finally, I am a little bit confused by the different outputs I can get from a solution. What is the difference between total heat flux and directional heat flux? And how do these differ from the results I get with a radiation probe on either surface?
      Thanks for the help :-)
    • Chandra Sekaran
      You can apply different boundary conditions on the same surface like temperature, convection and radiation.
      Directional heat flux is based on the rate of change of temperature in a particular direction such as X, Y or Z. Total heat flux is the vector sum.
      The radiation probe gives you the incident heat and amount of heat leaving the surface (emitted,reflected).
    • David Mercier
      To help you to understand such phenomena, you have access to different innovation courses:
      And soon a webinar about this topic with Ansys Discovery: https://www.ansys.com/events/cto-bu-next-generation-of-heat-transfer-teaching
      Cheers
  • The topic ‘Help with Steady State Thermal Analysis’ is closed to new replies.
