August 1, 2024 at 12:31 pm
August 8, 2024 at 10:40 am
Forum ModeratorThat looks like a 2d model. You may find it will work if you extrude the fault and then split with that volume/bounding faces. Booleans can be a little messy in 2d as contact can be zero because the surfaces have no thickness.Â
