September 11, 2024 at 7:26 am
nhanani4
Subscriberhi. Im new ansys user.
I want to ask if can give suggestion where did i do wrong that get the heave negative?did it correct the heave motion of floating structure is at structure motion> asctual response> global z?
2. or the data calculation for axial stiffness is problem?
thank for helping me
September 13, 2024 at 2:15 pm
Shuangxing Du
Ansys EmployeeGetting the heave negative may not be a problem. It just indicates that the COG z-position is below water surface in the time domain analysis.
Please check the followings:
(1) the global coordinate system's origin is defined at the mean water level and z-axis points upwards.
(2) from Hydrodynamic Diffraction -> Solution -> Hydrostatic, check if Ceter of Gravity Position is what you expect.
(3) from Hydrodynamic Diffraction -> Solution -> Hydrostatic, check if Actual Volumetric Displacement is nearly the same as Equivalent Volumetric Displacement.
(4) from Hydrodynamic Diffraction -> Solution -> Hydrostatic, check if horizontal position (x,y) of Center of Buoyancy to be nearly the same as that of Center of Gravity position.
5649
1885
1404
1303
