March 25, 2020 at 3:50 pm
bobd
SubscriberDear all,
I want to implement highlighted equation in Ansys, I'm following the tutorial (https://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node342.htm) on the Ansys site. But I'm not quite sure for which part part of the eq. I have to write an extra UDF and the where to implement it.
Thank you in advance,
BobÂ
March 25, 2020 at 10:25 pm
Rahul Kumar
Ansys EmployeeHello,Â
Please refer to the Fluent user guide, section 9.1.3.1 for single phase and 9.1.3.2 for multi phase.Â
RahulÂ
March 26, 2020 at 1:08 pm
bobd
SubscriberYes, I'm following that guide, but I'm not quite sure for which part part of the eq. I have to write an extra UDF and the where to implement it. Cause for example in the udf manual they write a piece of code, for the unsteady part:
do I have to implemented it exactly, the same, or change it to my "values"?Â
March 27, 2020 at 1:16 am
- The topic ‘Heat transfer’ is closed to new replies.
4673
1565
1386
1231
