July 6, 2023 at 12:55 pm
Agung Limowa
Subscriberhi, i need to model a heat flux based on coordinate, like if y<-50m , Heat = 150 -(y-50)*0.12, can fluent handle conditional based on coordinates ?
July 6, 2023 at 1:26 pm
Forum ModeratorHave a look at Expressions. I would tend to split the wall at y=-50m to simplify the setup, and also to have a separate surface for reporting. No need to, I just tend to try and keep models simple when I can.Â
July 6, 2023 at 2:10 pm
Agung Limowa
Subscriberi still didnt get it how to calculate using if function on ansys what
mean ? Â
July 6, 2023 at 3:27 pm
Forum ModeratorYou will need to read up on Expressions, and then use the Expression on the wall boundary condition.Â
July 7, 2023 at 3:44 am
Agung Limowa
Subscriberhi I have tried to calculate and create an expression but it has 2 different dimensions so I want to make the temperature increase as the position decline, so it has [m] dimension and [C] dimension. i have tried to split the expression but it didn't seem to work, what i should do
July 7, 2023 at 5:41 am
Agung Limowa
Subscriberi have solved the problem, thankyou
- The topic ‘Heat expression’ is closed to new replies.
5899
1306
