January 15, 2020 at 7:49 am
usm03
SubscriberHello Everyone,
I am trying to simulate the heat exchange problem in the Ansys Fluent. Refrigerant is flowing at -40 deg Celcius with a velocity of x m/s in a metal pipe placed in a chamber with 0.005 torr pressure (vacuum). I want to study the heat exchange due to conduction at pipe body, convection and radiation. Please guide me through the whole procedure. Is this problem can be simulated using Fluent or should I move to any other module? I have tried simulating this problem using youtube videos but I am not sure that the procedure is correct. Any help would be appreciated.
Thanks.
January 15, 2020 at 11:41 am
Forum ModeratorCheck you're still in the continuum phase for the vacuum chamber. It's all possible in Fluent, but if you're not seeing flow in the vacuum chamber, and don't care about the pipe flow Mechanical (Thermal) may be a better choice.
January 15, 2020 at 11:56 am
usm03
SubscriberGreat. Can you please share some step by step guide for both the modules. It would be really helpful.
January 16, 2020 at 10:57 am
Forum ModeratorHave a look in the Help system: there are tutorials all tools there.
- The topic ‘Heat Exchange by convection and radiation in approx Vacuum condition’ is closed to new replies.
6410
