TAGGED: electrostatics, fluid, hydrostatics, mechanical-apdl, system-coupling
January 20, 2021 at 1:49 am
18409680
SubscriberHey guys,nI've been working on modelling the HASEL actuator, specifically the peano HASEL actuator ( demonstrated in the following video). https://www.youtube.com/watch?v=-TKjJBZEZe4nI'm having trouble matching my simulated results with the practical results. before showing how I modelled the HASEL actuator below in Fig 1. shows how the HASEL actuator should look when it is 'fully strained'.n
nFig 1. the desired result that I want to simulatenI modelled the HASEL actuator in 2D with 3 element types as shown in Fig 2. belown
nFig 2. PLANE183 to represent the pouch (shown by the white board around the actuator)nHSFLD241 to represent the fluid (shown in purple)nTRANS126 to represent the electrodes force on the actuator (shown in red)nnthe mesh seems to me be good, with a few exceptions at the ends of the actuator.nMy issue is when I solve the model I can never quite reach the 'full strain' which is effecting my results giving zero displacement where the load would be attached Fig 3.nn
nnFig 3. a contour plot of the x displacement for the HASEL after a voltage has been applied. The red circle is were the load would be attached and the red square is the corresponding contour displacement value.No matter what is do I can not reach that full strain or get any reasonable strain at the load.nI even tried using the 'penalty method' to set the electrodes final displacement to the 'fully strained' position and I got the same result.nI seem to have reached some sort of limit with either the PLANE183 or the HSFLD241 that I can't exceed.nPlease let me know if anything isn't clear.nAny help will be much appreciated.nRegardsnLevin
18409680
SubscriberHere are the files that I have been running nfirst with the transducer elements supplying the force and  then with the penalty method setting the electrode displacement.nn -
January 21, 2021 at 12:11 pm
Karthik Remella
AdministratorHi,nPlease refrain from creating duplicate posts for the same question. We will answer your question here. nHey guys,I've been working on modelling the HASEL actuator, specifically the peano HASEL actuator ( demonstrated in the following video). https://www.youtube.com/watch?v=-TKjJBZEZe4I'm having trouble matching my simulated results with the practical results. before showing how I modelled the HASEL actuator below in Fig 1. shows how the HASEL actuator should look when it is 'fully strained'.https://ci6.googleusercontent.com/proxy/KF93GWA10LD-FCGVd0_oIySCB7B1tzyj8kJKv4o-TlNRO9MJVSKaMFE8KTBv4wyM_wPWUj_rnsXKc_OQNR_oVFxU0_3IWpR-AxIUMl0K=s0-d-e1-ft#https://us.v-cdn.net/6032193/uploads/PINZJ0441S9K/image.pngFig 1. the desired result that I want to simulateI modelled the HASEL actuator in 2D with 3 element types as shown in Fig 2. belowhttps://ci5.googleusercontent.com/proxy/hBVeao6Rk7v9IBs3wf9r3SeDpsHehhp4q8EUhDi850VcXBbUGoWG95XW_GLm8-lJrWJOJbSaZUafvzT6beaX2ikDJVKgjMmtmmBcykHj=s0-d-e1-ft#https://us.v-cdn.net/6032193/uploads/7WZ5EVQJJ3WG/image.pngFig 2. PLANE183 to represent the pouch (shown by the white board around the actuator)HSFLD241 to represent the fluid (shown in purple)TRANS126 to represent the electrodes force on the actuator (shown in red)the mesh seems to me be good, with a few exceptions at the ends of the actuator.My issue is when I solve the model I can never quite reach the 'full strain' which is effecting my results giving zero displacement where the load would be attached Fig 3.https://ci4.googleusercontent.com/proxy/hFmoVY5vfg4XsBRxPIQyqy3JNvgAS-FFwGb8bb9FSJzdmBuLqoWZwjULeYyOO0CuCzRGQ5PRgtCJ_o6syvQcxTIg7mKgBfuFgDaeVJIu=s0-d-e1-ft#https://us.v-cdn.net/6032193/uploads/TAY8282BQAFS/image.pngFig 3. a contour plot of the x displacement for the HASEL after a voltage has been applied. The red circle is were the load would be attached and the red square is the corresponding contour displacement value.No matter what is do I can not reach that full strain or get any reasonable strain at the load.I even tried using the 'penalty method' to set the electrodes final displacement to the 'fully strained' position and I got the same result.I seem to have reached some sort of limit with either the PLANE183 or the HSFLD241 that I can't exceed.Please let me know if anything isn't clear.Any help will be much appreciated.RegardsLevi/forum/discussion/23714/hasel-actuator-model
I'm closing this current dicussion.nKarthikn
- The topic ‘HASEL actuator’ is closed to new replies.
5884
1306
