January 19, 2022 at 1:11 am
chonkiat.lee
SubscriberHi, I have a table of acceleration with frequency for sine vibration simulation... but there is a requirement that the table is for Q factor more than 15.
May I know how does the Q factor affect the input for harmonic simulation? Thank you!
January 19, 2022 at 8:12 amSaumadeep Choudhury
For a damped harmonic oscillator, the measure of dampness an oscillator is is defined by the Q factor or Quality Factor (Q factor - Wikipedia). It is a dimensionless parameter.
Higher Q indicates a lower rate of energy loss and the oscillations die out more slowly. A pendulum suspended from a high-quality bearing, oscillating in air, has a high Q, while a pendulum immersed in oil has a low one. Resonators with high-quality factors have low damping so that they ring or vibrate longer.
Regards, Saumadeep
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
January 20, 2022 at 12:09 amchonkiat.lee
Subscriberthanks for your reply.
So, if I change the input of damping ratio, it would change the Q factor, right?
Thanks!
January 20, 2022 at 7:36 amSaumadeep Choudhury
Yes, it should.
Viewing 3 reply threads- The topic ‘Harmonic simulation with Q factor’ is closed to new replies.
5859
