September 12, 2024 at 8:25 am
rahul.sanghvi
SubscriberI am trying to use the grating coupler design (https://optics.ansys.com/hc/en-us/articles/360042800573-Inverse-Design-of-Grating-Coupler-2D). This example contains 3 steps and I am facing issues in the second step. While running the "pid_grating_coupler_2D_1etch.py" step, the software says that the base simulation file cannot be found or read. All the files are saved in the same folder but I dont understand why do I have this issue.Â
Has some faced a similar issue or does someone know a solution to this?
September 13, 2024 at 11:12 pm
Guilin Sun
Ansys EmployeeThere might be something wrong with the software or simulaiton file. Suggestions:
1: please close all files, and restart your computer. If it gives the same error, please have a clean installation, eg, delete all related software and reinstall: https://optics.ansys.com/hc/en-us/articles/5613618572947-Fixing-installation-or-licensing-issuesÂ
2: You may also need to redownload the example files since occasionally the files can be corrupted.
If it gives other error message, please write a new post.
5664
1890
1414
1304
