August 4, 2021 at 4:12 pmmgjeongSubscriber
Hello.
I am running some simple antenna and EMI simulations in HFSS.
August 6, 2021 at 4:31 amAndyJPSubscriberThis is an old infuriating question climbing up to lawyer offices, which Ansys refuses discussing officially, limiting itself to some cloudy general statements, often telling about fluid dynamics and other products when asked about HFSS.
Since it was discussed, try searching: /forum/discussion/comment/114807
And read ANSYS requirements carefully: automatic mode turns off GPU use.
August 11, 2021 at 1:03 pmVivekKambleAnsys Employee
Please refer to the following section in the help document https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/Electronics/v212/en/Subsystems/HFSS/Content/HFSS/GPUAcceleration.htm?tocpath=HFSS%20Help%7CHigh%20Performance%20Computing%7CGPU%20Acceleration%7C_____0
Hope this will help
Regards Vivek
Viewing 2 reply threads- The topic ‘GPU acceleration doesn’t seem to work’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- HFSS Incident Plane Wave excitement mode
- Ansys Maxwell 3D – eddy current
- How to calculate eddy and hysteresis losses of the core?
- Simulation of capacitor combining eddy currents with displacement currents
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- Maxwell circuit – PWM
- On-chip inductor design
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
Top Contributors-
1762
635
599
591
366
