Goodman Approach Stress Value
    • halilkimsesiz
      I have been running a question for fatigue life calculation and calculation of factor of safety. When I try to calculate factor of safety by using Goodman approach, ANSYS take the minimum stress value as zero while calculating stress mean and alternating. But the problem is minimum stress is not zero in this calculations, Could anyone give me a suggestion to get over this situation. Thank you to everyone.
    • Ashish Khemka
      You can change the Loading Type in Fatigue Tool. Please see if the following link is of help to you:
      Fatigue Analysis Application (ansys.com)
      Regards Ashish Khemka
    • halilkimsesiz
      First of all thank you very much. Problem is I can't change the loading type because I am running a autofrettage process which is like 670-0-400 (MPA). I choosed the cyclic loading as last step (400Mpa). It is working between 0-400. However, there is a plastical deformation because of first step which makes the minimum stress different then zero. I mean when the pressure is zero the minimum stress is not zero but ANSYS takes it as zero. Is there any solution advice for this situation please?
  • The topic ‘Goodman Approach Stress Value’ is closed to new replies.
