Giving thickness to structural members
    • tumulpurwar
      I have structure, where I have lot of structural members of same length, same shape, same size.
      The structure assembly I made in Spaceclaim as surfaces and now I shifted it to mechanical workbench.
      So I have nearly 28 members who have same length, shape (T girders)
      I want to select all together and provide thickness at once. I want provide thickness to these all 28 surfaces together, don't want waste my time, selecting every single surface one by one and than provide individually thickness.
      I want provide thickness and later do fem of these shell elements.
      Any hints?
      Thanks
      In Mechanical, if you have a list of surfaces in the Outline, click on the first surface, hold the shift key down and click on the last surface then enter a thickness in the Detail window. That will be applied to all 28 surfaces.
  • The topic ‘Giving thickness to structural members’ is closed to new replies.
