May 2, 2022 at 8:24 am
AnttiP
SubscriberHi,
I have been familiarizing myself with SIwave and as part of that I was working on the tutorial model I got completely different results from the first simulation (Resonant Mode analysis) than what is presented in the tutorial document. I tried to start the model building process from scratch again but I'm getting the same results again.
Expected results from the tutorial document:
May 2, 2022 at 10:19 amAnttiP
SubscriberHere is the link to the tutorial in question:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/Electronics/v212/en/home.htm%23../Subsystems/SIwave/Subsystems/Getting%20Started%20with%20SIwave%20-%20A%20PCB%20Model/Content/Introduction.htm%3FTocPath%3DSIwave%7CSIwave%2520Getting%2520Started%2520Guides%7CPCB%2520Model%7C_____1
Can someone else verify if they can get the results displayed in the tutorial in SIwave 2021R2?
May 2, 2022 at 10:52 amMay 31, 2022 at 6:21 pmPraneeth
Did you follow the same procedure as dictated in the tutorial. Please check once.
In this post, you have opened component format of the file where as the the actual file in the tutorial is the anf format file. Please check.
All the very best Praneeth.
June 1, 2022 at 6:57 amAnttiP
SubscriberI managed to figure it out; the figures plotted in the tutorial are from simulation results with all the filtering capacitors disabled. I don't think that's mentioned in the tutorial or I managed to miss it but I managed to replicate the tutorial results by disabling all the capacitors in the design.
June 1, 2022 at 8:19 amPraneeth
Thank you for posting in the learning forum. We appreciate your participation in the forum.
Regards Praneeth.
Viewing 5 reply threads- The topic ‘Getting Started with SIwave: A PCB Model tutorial and not getting same results’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Ansys Maxwell 3D – eddy current
- Difficulty/Obstacle: “Parasolid entry check failed for part:”
- Maxwell circuit – PWM
- Plotting Ex, Ey and Ez in vector forms individually
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Y wiring method and the start and end points of winding.
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
- Ansys Resonance simulatioin error
Top Contributors-
2247
919
599
591
497
