February 17, 2021 at 9:31 am
AMaity
SubscriberHinI have the very first version of the cathodoluminescence script (written by Dr. James pond and my phd research group). However the files are attached herein.nOne can calculate the CL images with this script file. And to do this, one needs to run the line scan through X and Y axis (here I have selected line scan along X and Y with 10X10 points). But I do not know why I am getting this error problem: Error:Â /FDTD_Simulations/Triangle/triangle_500nm/sp_ebeam_image.lsf line 86: in sourcenorm: no source named ebeam::s1 was foundnn -
February 17, 2021 at 6:01 pm
Kyle
Ansys EmployeeHello,nThis error is occurring because the sourcenorm command is looking for a source object named ebeam::s1 but it can't find it in the Objects Tree. I believe I answered the same question in this post:https://kx.lumerical.com/t/cathodoluminescence-spectrum/75965/2nHere was the solution:nI believe that this is because the "s1" source is outside the simulation region as well, when I changed this to the "s595" source, which is inside the simulation region, the script ran without error, and the plot and text file are created.nDoes the script work if the s1 source is moved into the simulation region, or you use a difference source that is in the simulation region?n -
February 20, 2021 at 12:22 pm
AMaity
SubscriberThanks a lot for pointing out the source of error. Yeah! there was a mistake in choosing the the coordinate. I am trying to run the model after modification. Let you know the status.nThanks a lot again.nRegardsnAchyut n -
February 23, 2021 at 2:29 am
Kyle
Ansys EmployeeYou're welcome! Let me know if you have any questions.n
- The topic ‘Getting error in simulating the CL images’ is closed to new replies.
Ansys Innovation Space
1461
1272
1124
