June 3, 2019 at 9:12 pm
Goddy
SubscriberI am doing some analysis on a hip stem. And I want to apply a force to the center of the head. In the scoping method for geometry selection, when I select vertex so I can pick just the point at the center, it is unable to do that selection. So I used a remote force and selected the top face so the force will be applied at the center of that geometry. I don't know if doing it that way has the same effect as having a point force at the center.
I'll like my output to be directional deformation, specifically that at the point where the force is applied but I am unable to select that point still. So my question is how can i select that midpoint so the results I get is the directional deformation at the point were the force is applied? I was able to select a node at the center I don't know if that is appropriate.Â
find below a picture which kind off shows what I'm talking about. You'll see the force acting at the center of the scoped face.
June 7, 2019 at 4:31 pm
Sandeep Medikonda
Ansys EmployeePlease Click on the Remote Force and promote the point to a remote point. You can then do the same and create a Named Selection which is right at the middle of that surface.
You can use the Named Selection in the directional deformation evaluation as shown:
Here is a very helpful article on Remote Objects.
- The topic ‘Getting Directional deformation from a remote force’ is closed to new replies.
6284
