December 27, 2024 at 5:51 pm
yannic.j.gagnon.civ
SubscriberHello,
I am doing a simulation of a tensile test of a rectangular unidirectional carbon fiber composite. I am pulling one end of the rectangular piece and fixing the other end. I know how to get stress/strain and inverse reserve factor in the solution. What I would like to know is the strength of the composite; that is, the stress at which the composite fails. Another way to frame the question is that I would like to know the stress the moment the inverse reserve factor becomes greater than 1. How can I get this?Â
Thanks in advance.
January 16, 2025 at 10:16 am
Ashish Khemka
Forum ModeratorHello,
Please see if the following forum thread helps you: Evaluate failure in composite specimen
Ashish Khemka
January 16, 2025 at 5:25 pm
yannic.j.gagnon.civ
SubscriberThanks for the link. That person is dealing with a similar situation. Their approach is a little different from mine though. Maybe another way to solve my problem is: is there a way to plot the inverse reserve factor as a function of time or simulation step? This can be done with a different property like max stress but when I try to make a plot of the IRF only a single datapoint shows up.
January 20, 2025 at 8:37 am
Ashish Khemka
6790
1332
1147
