January 11, 2019 at 5:59 am
bhanu34
SubscriberHi
Does anyone know how to get mat ID of material with certain young's modulus or Poisson's ratio through APDL commands ?
January 11, 2019 at 8:14 am
sathya
SubscriberHi Bhanu,
I guess there must be command using *GET.
In the meantime , you can use MPLIST,ALL to list all material data defined as a text file.
Then just search for the corresponding magnitudes of EX or PRXY and find the mat ID associated with the data.
January 11, 2019 at 10:41 am
bhanu34
SubscriberHi Sathya
Can you please be little more elaborate on *GET command?
Thanks
January 11, 2019 at 1:03 pm
jpasquerell
Ansys Employeedo a *get of the maximum material id number into a parameter- see the help for *GET with the entity of MAT
create a do loop from 1 to the maximum material id number parameter
*get of EX for the do loop counter number at the desired temperature - see the help for *GET with the entity of MPLABÂ (MPLAB can be any of the actual material property labels including PRXY for Poisson's ratio).
*IF the EX parameter matches the desired then
set the output mat id to be the current loop parameter value then *EXIT so no more loops
*ENDIF
*ENDDO
January 14, 2019 at 5:55 am
sathya
SubscriberHi ,
I am using the following syntax but it is not able to read for discontinuous mat id like 1,50,,etc.
Can you correct me?
*ask,ym,Enter the magnitude of EX in system units
*get,matmax,MAT,0,num,max
*do,i,1,matmax,1
*get,prop,ex,i,,,
*if,YM,eq,PROP,THEN
mplis,i
*Exit
*endif
*ENDDO
January 18, 2019 at 12:55 pm
jpasquerell
Ansys EmployeeI ran you commands and they worked for me but you can add another *if level to not test prop vs YM when there is no EX for a mat id as prop is an undefined parameter which has a value of 2**(-100) . Â
!*ask,ym,Enter the magnitude of EX in system units
*do,i,1,matmax,1
*get,prop,ex,i,,,
*if,prop,ne,2**(-100),THEN
*if,YM,eq,PROP,THEN
mplis,i
*Exit
*endif
*endif
*ENDDO
- The topic ‘Get material data in ANSYS APDL’ is closed to new replies.
6535
1311
