Get Domain & Lookup Thread
    • Nida
      Dear Sir,
      attached is the UDF, where I am trying to get x and y coordinates of my 2D domain boundary.
      The Zone ID that I am looking in Boundary Condition panel is "4" for the boundary where I want to find the coordinates.
      The UDF is compiled and loaded without any error but it is giving me following error when I run Execute of Demand
      999999: mpt_accept: error: accept failed: No such file or directory
      999999: mpt_accept: error: accept failed: Node 0: Process 17792: Received signal SIGSEGV.No such file or directory
      999999: mpt_accept: error: accept failed: MPI Application rank 0 exited before MPI_Finalize() with status 2
      Cannot merge similar NUMANode objects with different OS indexes 0 and 1
      The fl process could not be started.
      I am confuse in these lines of code and sure that error is here. What I need to put Get_Domain(?). My case is simple 2D fluid domain for incompressible flow and I want to find x & y coordinates on boundary.
      int ID=4;
      Domain *d = Get_Domain(1);
      Thread *tf = Lookup_Thread(d, ID);
      Kindly clear it. Thank you
    • DrAmine
      We do not debug UDF. Just share what you think is causing an issue. The three lines are ok
    • DrAmine
      And we do not download attachments
  • The topic ‘Get Domain & Lookup Thread’ is closed to new replies.
