3D Design
3D Design
Geometry Tolerance
    • Autonewbie
      I am trying to import a geometry file (.iges & .x_t) to APDL but warning and error messages pop out: Line XXX on area YYY is not on the area within a tolerance. This area could have problems in future Boolean operations. (see the BTOL command); Cannot project lines to surface ZZZ. Surface could be twisted or lines do not lie on the surface.
      I tried to adjust the Boolean Tolerance but it did not work. Any suggestions are much appreciated!
Viewing 0 reply threads
  • The topic ‘Geometry Tolerance’ is closed to new replies.
