Preprocessing
Preprocessing
Geometry Issue; Faces of Sheet is not on XY Plane
    • hassa124
      Good afternoon,
      I created a 2-D Maxwell motor and wanted to analyze it, but the error code:
      Part "Region": Faces of sheet is not on XY plane
      The Region being below
    • Keyur Kanade
      As far as I know it should in XY plane. If it is not in XY plane, it will throw error. nPlease make sure that your 2D geometry is in XY plane only. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • hassa124
      How do I make sure it's in the XY plane? I checked the global coordinate system and it didn't have any issues.n
    • Keyur Kanade
      Let Maxwell expert pitch in n
    • NKC
      nAs a preliminary check, change the orientation to left or right and see if you are seeing anything out of the plane.nTake a look at the below example.nIf everything is in XY plan you should see the screen as shown belownnnregards,nNavyan
    • hassa124
      I've checked, and everything seems finenBut the issue persistsnn
    • NKC
      Hi,nCan you help me understand how you created this 2D model.nCreated from RMxprt (or) Imported a dxf file (or) Created from a imported 3D model?.
Viewing 6 reply threads
  • The topic ‘Geometry Issue; Faces of Sheet is not on XY Plane’ is closed to new replies.
