November 11, 2024 at 12:40 am
jjh4804a
SubscriberRunning the same model on each version results in the following error.
2020 R1 - Error: 'Geometry does not comply with pure rotation motion!
2019 R2 - Error: 'm2dfs_solve'I tried two ways
1. Mesh > initial mesh settings > use slider > change
(Try two versions)
2. Tools > Options > General Options > Desktop cofiguration, then check the first box
(There was no box in the 2019 r2 version)
I want to know the solution. Please. -
November 11, 2024 at 3:04 pm
Timos
Ansys EmployeeHello, according to the error 'Geometry does not comply with pure rotation motion!' there should be an issue with the geometry / band of your setup. We would need further information in order to help you.
Thanks!
November 12, 2024 at 11:49 am
jjh4804a
SubscriberHi Timos I solved this problem. Thank you for your heart.
5694
1891
1419
