December 12, 2024 at 5:23 pm
Clarkt
SubscriberGreetings,
I am trying to perform a geometry condensation of an assembly consisting of two bodies. The connection between the two bodies should be modeled as a constant 6x6 stiffness matrix between two remote points.Â
The modal analysis was performed with MPC184 elements whose formulation is not supported by the geometry condensation feature. Using a bushing connection or a COMBI250 element is not sufficient because it covers only the diagonal terms of the stiffness matrix and in my case the off-diagonal terms do play an important role.
Is there anything I could do to overcome this issue in Workbench?Â
Thanks in advance!
December 13, 2024 at 1:53 am
peteroznewman
SubscriberI had some advice on a related topic in this discussion.
If you share some more details about your model, you might get some suggestions specific to your model.
December 13, 2024 at 7:50 am
ErKo
Ansys EmployeeÂ
Hi
By geometry condenstaion I assume here you mean about creating super elements via condensed parts.
If that is the case then
Use bushing type of joint (formulation: MPC and 6×6 matrix - needs radians as units) and that goes well with condensed parts (at least it runs with no errors)
https://innovationspace.ansys.com/forum/forums/topic/how-to-parameterize-stiffness-coefficients-for-a-bushing-joint/Â
All the best
Erik
December 13, 2024 at 10:35 am
Clarkt
SubscriberThank you for your answers guys. To give you some further insight on the application, it's about a shaft and housing system and the matrix represents the bearing stiffness. Indeed, I am trying to derive a superelement using modal reduction. So if I understand properly I should create a dummy line element that I will convert into MATRIX27. Then I should define bonded contacts between the line element's vertices and the shaft and bearing faces. Are there any recommendations regarding the bonded contact formulation? Should I go for MPC? If yes, with what constraint type?
December 13, 2024 at 10:56 am
ErKo
Ansys EmployeeÂ
Thiink best to skip Matrix27 – take that back as it is tricky to use.
See below what I suggest:
In workbench mech., create a bushing type of joint between parts (formulation: MPC – and 6×6 matrix in worksheet – needs radians as units to see 6×6) and that goes well with condensed parts (at least it runs with no errors) – I have tried it in 2024 R2 and worked
All the best
Erik
December 13, 2024 at 12:13 pm
Clarkt
SubscriberDear Erik,
Just tried exactly what you said but (surprisingly) it didn't work. Here's the message I got:
This Condensed Part is invalid due to MPC formulation Bushing joint(s) completely contained inside the condensed part.
Maybe it's because the joint is completely within the assembly that I am trying to reduce.
What could go wrong with the matrix element?
December 13, 2024 at 2:54 pm
ErKo
Ansys EmployeeHi
Tried it between two parts and it worked fine.
Can you show a bit how you use the bushing between parts.
All the best
Erik
December 13, 2024 at 3:24 pm
December 13, 2024 at 5:43 pm
ErKo
Ansys EmployeeÂ
Hi
Can not do like that.
So create 4 different/separate condensed parts and not only one with all 4 bodies in it as that does not work.
All the best
Erik
December 16, 2024 at 8:12 am
Clarkt
SubscriberHi Erik,
Thanks for your answer once again. Do you think that creating 4 matrices separately and then combining them (properly of course) into one would be equivalent to extracting the matrix from the complete assembly?
Also, if I still need to go for the full assembly, the MATRIX27 method is the only way to go right?
5899
1306
