3D Design
3D Design
    • chandu659
      previously i read the same discussion on my kind of error ,I have done everything suggested in the geometry but still am unable to remove the error , when i am creating a boolean operation for geometry it shows that it results to non-manifold geometry .can you please help me to solve  this issue .
      thank you
       i am unable to perform boolean operation ,showing an error it results in a non manifold geometry , i have proceeded to fluent solution ,but my internal geometry is missing .Why i am facing this error ?only cusped geometry are making an error for me
      Does the curved shape touch the enclosure at the blunt end? If so let it stick out by a little bit and try again.
    • chandu659
      facing same error..
    • Keyur Kanade
      are those solid bodies or surface bodies?
      make sure you have solid bodies.
      make use of symmetry.
      split geometries in half and then try boolean.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • chandu659
      thank you it worked
Viewing 4 reply threads
  • The topic ‘geometry’ is closed to new replies.
