May 4, 2020 at 10:03 pm
ywang2524
SubscriberHi,
   The body is not sweepable since the pitch is too short comparing to the coil diameter. I have also tried patch conforming, match control, automatic method. None of them worked, which method and settings should I use to generate mesh?
   Thanks!
May 4, 2020 at 11:24 pm
May 5, 2020 at 11:07 am
Forum ModeratorTube side will sweep. Shell side will need to be tet mesh.Â
May 6, 2020 at 2:55 am
Keyur Kanade
Ansys Employeetube can have hex.Â
outside of tube would be tet.Â
please make sure that you split this geometry further to have more no. of faces.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
May 16, 2020 at 9:14 pm
ywang2524
SubscriberThanks for the reply!
Am I supposed to split the body in DesignModeler? I was trying to use face split but it did not work. Thanks!
- The topic ‘Generate mesh for shell side body of helix tubes with short pitch’ is closed to new replies.
5059
1765
1387
1248
