June 4, 2024 at 6:51 am
YH
SubscriberHello,
I would like to calculate pipe flow with a branch. Since entrance length is very long comparing the branch, i wann use coarse mesh on the entrance length, fine mesh on the branch like the figure.Â
I made 1 part and 2 bodies. But the mesh is not shared at the bondary between the branch body and the entrance length body. Would you tell me how to do that? Thank you.Â
June 5, 2024 at 6:14 am
Keyur Kanade
Ansys EmployeeYou will need to use Share Topology in DM or SpaceClaim and then go to meshing. It will give you conformal mesh.
You can also check Body of Influence for giving local sizing.Â
Please check following videos
Ansys Meshing Sizing:
https://www.youtube.com/watch?v=w4q6q8nKF3UDM Share topology:
https://www.youtube.com/watch?v=IO4ZtwZdD2ISpaceClaim Share topology:
https://www.youtube.com/watch?v=h43E1YO1LiMAnsys Meshing: Meshing Methods:
https://www.youtube.com/watch?v=nEOC8rDnnRoÂ
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
June 6, 2024 at 1:01 am
YH
SubscriberHi Keyur
Thank you for telling me. Shared topology works well.Â
I have one question. I used Design Modeler's ShareTopo at first, however the mesh did not shared in two bodies. After I moved the geometry to SpaceClaim and applied Shared Topology, then the mesh was shared.Â
I think Design Modeler's ShareTopo works since the edge color is pink indicating shared like the picture. Can you identify the reason?
BestÂ
YH
- The topic ‘Generate locally fine mesh’ is closed to new replies.
5884
1306
