November 20, 2019 at 6:39 pm
FabricioMorais
SubscriberHello,
I'm wondering to understand how does workbench process the frictionless contact on a Modal Analysis.
I do know that the Modal Analysis is a linear analysis and only take in consideration linear contacts, any non linear contact is ignored (according to the help "3.1. Uses for Modal Analysis"), however I do have a situation where I have lots of covers bolted to a more rigid body along the extremities and the faces of both are touching each other. That will not allow some of the displacements.
If I run that model considering NO Face-To-Face contacts, I have very low natural frequencies but none of them are actually real. So I decided using frictionless contact. The results were 3 times better, the displacements shown were very close to what I expect on the reality. But..... How did it run a nonlinear contact on the Modal Analysis???? Does it convert the contacts into Bonded???
Well I did that test, I converted all frictionless contacts into bonded and run again. The results were again even better than with frictionless contacts, though not real, I know!
So again my question is, How does Workbench run Frictionless face contact on a Modal Analysis? Can I even trust the results???
Thanks!
Fabricio Morais
November 20, 2019 at 9:19 pm
peteroznewman
SubscriberHello Fabricio,
Don't trust an FEA result, do verification and validation.
Modal is a linear analysis, so only linear contacts are allowed, which are Bonded and No Separation. All nonlinear contacts such as Frictional and Frictionless are automatically converted to a linear contact according to the table below which came from some training material.
I spent 15 minutes searching for a table like this in the ANSYS Help and could not find it. Maybe someone from ANSYS can find it for us.
Kind regards,
Peter
- The topic ‘Frictionless Contact on Modal Analysis’ is closed to new replies.
6435
