March 31, 2020 at 6:49 am
azolo
SubscriberHello everyone,
For a point on my model I need the Frequency Response Function (FRF) of the Z-rotation after applied torque. In ANSYS Mechanical APDL there is the option but in ANSYS Workbench I don't find it. Is there a way to do it also in ANSYS Workbench?
I hope someone can help me out.
April 11, 2020 at 6:40 am
azolo
SubscriberHow can I get the rotational displacement in Z (rz) for a point in ANSYS Workbench?
April 11, 2020 at 3:40 pm
April 13, 2020 at 10:52 am
azolo
SubscriberI have now found a way but I don't know if there is a easier way.
My steps to get the rotational FRF are:
- Create a remote point on the point of the part where you need rotational displacement
- Add the following APDL command to the remote point
    measure_pilot=_npilot
- Create an APDL command in the solution of the harmonic response (RS).
(Since I need the frequency range from 0 to 4000 Hz and the solution itervalls are 1000 I do this through a script)
set,list
*cfopen,'rot_z_FRF','txt'Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â ! create a text file
*do, i, 1, 1000 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â ! the solutions intervalls from the analysis settings
set,1,i,,AMPLÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
*get,my_freq,ACTIVE,,SET,FREQ
my_rot_z=ROTZ(measure_pilot)
*vwrite, my_freq, my_rot_z
(F8.0,g16.5)
*enddo
*cfclose
How can I read the value of the solutions intervalls automaticly from the analysis settings?
- The topic ‘Frequency Response Function (FRF) for rotation in ANSYS Workbench’ is closed to new replies.
6149
