May 8, 2024 at 2:47 am
Atif Ismail
SubscriberDear Seniors,Â
I am a graduate student working on hydrualic fracturing simulation using 2way coupling of static mechanical and fluent.Â
I have considered a cylindrical geometry with a hole in the center. A pre-existing semi elliptical crack is considred in the simulation.Â
How I select the fracture top face and bottom face as a coupling region? As if I select the area A as a coupling region (Figure 1), the sif is highest at the point B and C where as SIF should be highest at the fracture front (yellow circled) (Figure 2). Kindly if you may guide me in this regard. -
May 20, 2024 at 3:05 pm
Ashish Khemka
Forum ModeratorHi,
Can you please refer to the thread below and see if you have followed the steps indicated here?
SMART Crack Growth with Semi-elliptical crack (ansys.com)
Ashish Khemka
June 3, 2024 at 2:46 am
Atif Ismail
SubscriberÂ
Thank you for your reply Mr. Khemka.Â
I have read the shared link.Â
I am comfortable in using SMART Crack Growth but I am unable to use that in two way-FSI (Structural and fluent).Â
Kindly confirm if SMART Crack growth works in two way-FSI or not? If it is possible if you may share any relevant reference for that.Â
As if I select the area A as a coupling region (Figure 1), the sif is highest at the point B and C where as SIF should be highest at the fracture front (yellow circled) (Figure 2).Â
If you may comment on the posted issue.Â
Regards,ÂÂ
- The topic ‘Fracture Propagation Study by FSI’ is closed to new replies.
5654
1890
1414
1303
