Four-Cell Bipolar Electrolyzer Stack Setup in Fluent 2026 R1
    • Hasan Celik
      I am developing a three-dimensional, four-cell anion-exchange-membrane/alkaline water-electrolyzer stack model in Ansys Fluent 2026 R1. I would appreciate guidance regarding the correct electrical configuration of a true bipolar stack.
      I am using:
      • Potential/Electrochemistry
      • Electrolysis and Hâ‚‚ Pump Model / Electrochemical Devices
      • Device type: Alkaline Electrolysis
      • Multiphase formulation
      • Resolved MEA-layer modelling
      • Butler–Volmer electrochemical kinetics
      • 1 M KOH electrolyte
      • Operating temperature: approximately 333 K
      • Operating pressure: 1 atm
      Each of the four cells contains separate zones for:
      • Anode current collector
      • Anode flow channel
      • Anode porous transport layer/GDL
      • Anode catalyst layer
      • Membrane
      • Cathode catalyst layer
      • Cathode porous transport layer/GDL
      • Cathode flow channel
      • Cathode current collector
      The individual cells are intended to be connected electrically in series through bipolar connections:
      • Cell 1 cathode current collector ↔ Cell 2 anode current collector
      • Cell 2 cathode current collector ↔ Cell 3 anode current collector
      • Cell 3 cathode current collector ↔ Cell 4 anode current collector
      Only the two external surfaces are defined as the stack terminals:
      • External anode terminal
      • External cathode terminal
      The intended total stack voltage is initially 6 V, corresponding to approximately 1.5 V per cell.
      The contact zones are named:
      bp12_contact
      bp23_contact
      bp34_contact
      However, Fluent repeatedly gives warnings such as:
      Warning: Anode side is electrically connected with cathode side
      (cell2_anode_cc and cell1_cathode_cc)!
      (cell3_anode_cc and cell2_cathode_cc)!
      (cell4_anode_cc and cell3_cathode_cc)!
      After that I have defined the boundry condtions and started to solve.
      The solution later becomes unstable and produces nonphysical currents and floating-point errors.
      Could you please clarify:
      1. Does the resolved Alkaline Electrolysis model support a true multi-cell bipolar stack?
      2. Are these electrical-connection warnings expected for series-connected cells?
      3. How should the bipolar interfaces be defined?
      4. Should I apply the total stack voltage, for example 6 V, or the individual cell voltage, for example 1.5 V?
      5. Is there any Fluent stack tutorial or example available?
      Sincerly,
Viewing 0 reply threads
