LS Dyna
LS Dyna
forrtl: severe (157): Program Exception – access violation
    • hansenli
      I encountered this error when I started a simulation.
      forrtl: severe (157): Program Exception - access violation
      It's the first time I enconter this error. I think it might be related to the mat_piecewise_linear_plasticity, because it's also the first time using this material. Is there any other way to debug?
      Thanks!
    • Fernando Torres
      Hi, you may check the following
      ~Recheck for the incomplete/inaccurate parameters defined in material model or EOS etc
      ~Recheck the contact definitions
      ~If using LS-prepost, try to use the the (default) same version as of the solver
      Thanks!
  • The topic ‘forrtl: severe (157): Program Exception – access violation’ is closed to new replies.
