November 1, 2022 at 2:58 pmZhen Hui LiewSubscriber
The "Formula SAE Composite Monocoque Chassis Analysis" is very helpful.
However, there is no training file for download. May I know where I could locate the geometry file so that I could attempt the composite analysis on my student version?
Thanks in advance for the help.
December 8, 2022 at 8:46 amSaurabh PatilAnsys Employee
Thank you for your feedback, it’s great to know that you are finding the course helpful. You can find the geometry file on this page Geometry Preparation Using Ansys SpaceClaim — Lesson 1 - ANSYS Innovation Courses.
-Saurabh
June 28, 2023 at 6:48 amNellaiapperanandSubscriber
Hi, just wanted to let you know that the Workshop Geometry file is wrong. The link only has a circular hollow tube. Can you please share the correct geometry file used in the workshop?
/courses/index.php/courses/formula-sae-composite-monocoque-chassis-analysis/lessons/geometry-preparation-using-ansys-spaceclaim-lesson-1/
June 28, 2023 at 7:37 amSaurabh PatilAnsys Employee
Thanks for letting us know this bug, our team will look into it and soon replace it with the correct file. I will let you know soon once its done. If needed for the time you can use this workaround by extracting the geometry file from the workbench archive on this page and unsupress the solid bodies to get the true model. Hope you find this helpful.
Thanks
Saurabh
- The topic ‘Formula SAE Composite Monocoque Chassis Analysis – Geometry File’ is closed to new replies.
1416
599
591
565
366
