December 26, 2024 at 8:14 pm
euklidespl
SubscriberHello,Â
Is it possible to use the Yoshida Uemori model and the Barlat model while taking into account the influence of the plastic strain rate on the yield stress?
December 27, 2024 at 4:32 pm
December 27, 2024 at 9:27 pm
December 27, 2024 at 10:11 pm
Armin
Ansys EmployeeNo problem at all.
Yes, for the Barlat model you can input C and P which are the coefficients of Cowper-Symond's equation to scale the reference hardening (stress-strain) curve at different strain rates. It is sometimes easier to directly input the stress-strain curves (from physical experiments, for example), but if you have the C and P coefficients available, you can use the Cowper-Symond's method as well. -
December 28, 2024 at 12:11 pm
euklidespl
SubscriberIn the Ls-Dyna manual I read that material number 242 integrates the Yoshida Uemori model with Barlat yld2000 (mat_133). While the mat_133 manual mentions the possibility of taking into account the strain rate, in the manual for mat_242 I found no mention of the strain rate.  I learned from you that it is possible to link the effect of strain rate with the barlatyld2000 model, but should I link the barlatyld2000 model (which takes into account the strain rate) with the yoshida uemori model? I'm asking because in the mat_242 instruction which links the Yoshida uemori  model with barlat_yld2000 there is nothing about the strain rate.
December 30, 2024 at 4:06 pm
Armin
Ansys EmployeeI see your points.
Looking at the MAT_242 incorporating kinematic hardening, it appears to me that the hardening of the material is inherently considered through the Yoshida-Uemori coefficients (unlike the MAT_133 where you could input the hardening curve separately). I would suggest you look at the Yoshida-Uemori equations to investigate if the strain rate sensitivity can be considered from there.
5794
