February 5, 2023 at 2:16 pm
Mahmoud Nassar
SubscriberHi,
I am trying to solve an oscillating airfoil using system coupling between Fluent and transient structure.
I was able to successfully run the benchmark problems for FSI on its own. Further, I was able to solve an oscillating airfoil by imposing the motion to the airfoil as a rigid body using Define Cg motion and dynamic mesh.
Now, my question is how I can impose the motion for the airfoil in fluent and also define the same airfoil as a system coupling ?!
The airfoil is flexible and I have to use 2-way FSI
What should I do and what UDF do I have to use?!Any help will be much appreciated.
February 7, 2023 at 9:30 am
SRP
Ansys EmployeeHi,
I suggest to check fluent tutorial on FSI: Chapter 28: Modeling Two-Way Fluid-Structure Interaction (FSI) Within Fluent (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Hope this helps you
Thank you
Saurabh
February 7, 2023 at 6:22 pm
Mahmoud Nassar
SubscriberThank you, this feature is new. This will be very helpful
on the other hand, my final goal is to couple Piezo+Fluent+Transient Structure.
Do you have any idea how to impose the oscillation motion within FSI (not the intrinsic FSI)?!
I will need to couple piezo in the next step
- The topic ‘Fluid-Structure Interaction for a moving body’ is closed to new replies.
6575
1311
