February 27, 2023 at 10:23 pm
Alex Yang
Subscriberhello, I have a problem in simulating wave impact. For some reason, the water within the simulation ignores the solid waterbreaks in ansys fluent I will attach a clear image of fluid ignoring the solid (unrelated to the actual simulation). How can I fix this issue? Thanks in advance for your time and help.
February 28, 2023 at 11:11 am
Forum ModeratorWhen you built the CAD did you split or subtract out the wavebreaker solid, or just add it to the model and head to meshing?Â
February 28, 2023 at 3:11 pm
February 28, 2023 at 3:28 pm
Forum ModeratorThere should be some tutorials in the SpaceClaim documentation. Start with those. I also suggest you read up on the VOF model as trying to mesh that isn't going to give a low cell count model. You may then want to review the Cell zone condition "porous media".Â
February 28, 2023 at 5:48 pm
Alex Yang
SubscriberThank you for your advice, how can I import a stl file into designmodeller without issues? When I import from spaceclaim I cannot do Boolean subtract due to an error. Thank you.
March 1, 2023 at 9:55 am
Forum ModeratorWith difficulty, stl's aren't traditional CAD so it can get interesting. Have a look at the facet tools in SpaceClaim, and Fluent Meshing.Â
- The topic ‘fluid ignoring solid objects’ is closed to new replies.
6560
1311
