Fluid-Dynamics Verification Manual
    • mzhossain2001
      I don't see the input files it referred in the manual. like rot_conc_cy1.cas, etc. nIs it accessible? Any way to get the files referred over there?n
    • Keyur Kanade
      I think the files are available on customer portal. If you do not have access to customer portal, please check with your professor. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • mzhossain2001
      I am looking for those files by myself and need a yes or no answer about it's availability. Any place to get that?n
    • DrAmine
      They are available. Access is granted on the customer portal as my colleague highlighted.n
    • mzhossain2001
      So, they are not available for those who doesn't have access to the customer portal. I suppose, it shall be available to all as per the software capabilities offered/delivered.n
    • DrAmine
      It is for now only avaliable as described.n
    • mzhossain2001
      Thanks for the confident info. Though I expected a resolution accessible for all.n
    • DrAmine
      You can launch the Online Help there go to Verification Manuals. Chapter 1 Sub chapter 3 it offers a way to download the files.n
    • mzhossain2001
      Can I get the link? here or by email.n
    • DrAmine
      In Fluent just hit F1n
    • DrAmine
      /forum/discussion/3978/how-to-access-the-ansys-online-helpn
    • mzhossain2001
      I will ask for the exact link to get to exactly into the fvm input files, if possible. Thanks.n
    • mzhossain2001
      I am using Ansys student 2020 R2. I am Not sure if that option is available to this version.n
    • DrAmine
      You can access the online help?n
    • mzhossain2001
      Yes, I do. nFor example, I see the Ansys Mechanical APDL verification manual, that comes with input batch files. So, no problem with that.nFor fluid, I see the fluid- dynamics verification manual, but it only refers to the input FVM file numbers - but it is not showing the input file, itself. nIf I open fluent launcher - I can open fluent help files [ chapt4 and chapt43], but that is not coming up with any FVM input files.nHence, I need exact direct link, applicable for 2020 R2. Or may be all input files docs emailed to me. Thanks. n
    • DrAmine
      I do not communicate with Forum members via Emails only when there is something critical. I apologize that the link is not mentioned in the 2020R2 help. It will be mentioned in the upcoming release. Try this link: https://storage.ansys.com/doclinks/mbu.html?code=verifi_fluids-201-MLU-N1a if not working for you You will need access to customer portal or wait till next release.n
Viewing 15 reply threads
  • The topic ‘Fluid-Dynamics Verification Manual’ is closed to new replies.
