Fluent Udf Wall
    • francescone96
      Hi everybody, nI have a cubic geometry and i'm performing a Transient Analysis in Fluent. nIn one of the 6 faces of the cube i have to apply, as a boundary condition, a temperature dependent Heat-Flux with an UDF.n So i need to understand how to write this UDF in order to accomplish that. I'm quite new to UDF, so i tried to do that but without getting any results.
    • DrAmine
      Did you into the Customization manual? Hit F1 whenver you are In Fluent to open the help and look after define profile. Alternative is to use Fluent Expression.n
  • The topic ‘Fluent Udf Wall’ is closed to new replies.
