April 27, 2023 at 1:37 am
Shreyansh Jangitwar
SubscriberWhen I try to open it after meshing and importing geometry it shows "Ansys is unable to validate the connection"
April 27, 2023 at 10:08 am
Kishan Konannavar
Ansys EmployeeÂ
Hello
There are couple of older posts with the same problem, did you happen to go through them?Â
The Fluent application failed to validate the connection, what to do? (ansys.com)
Fluent Failed to validate connection (ansys.com)
Which version of Ansys student are you facing this issue with? Does the same happen with other versions?
Thank you
April 29, 2023 at 8:21 am
Shreyansh Jangitwar
SubscriberYes, I went to the previous post but could not find anything helpful. I am using ansys 2023 R1 student version.Â
April 30, 2023 at 3:53 pm
Kishan Konannavar
Ansys EmployeeDid you try installing and launching a different version other than 2023R1?
October 15, 2023 at 7:34 am
Antonio Peretto
SubscriberI have tried all the suggestions found in this forum but it still doesn't work. The message is always "unable to validate connection". I have installed twice student 2023 r2 version and I have windows 11. I have also tried R1 but nothing.
Please can somebody gives some other suggestions?
many thanks
- The topic ‘Fluent Setup not working’ is closed to new replies.
6660
1313
