Ansys Products
Ansys Products
Fluent Problems
    • dorianrendon
      I recently installed the ANSYS academic version successfully through my school.
      As you can see in the image attached Fluent actually opens up but with a message that reads:
      "Host spawning Node 0 on machine "LAPTOP-I33GJDMB" (win64).
      WARNING: No cached password or password provided.
      use '-pass' or '-cache' to provide password."
      and that's it. I am not able to use it, whatsoever. The cursor appears as if something it loading.
      Although, it lets me click on Domain, Physics, User-Defined, and the others on the top except for File,
      but still nothing else works. Anything else that I click on my laptop makes an error sound.
      So I added a second screen shot to help you see how it is acting on my end.
      Screen Shot
    • tsiriaks
      Try this
      In Fluent Launcher, click more options -> parallel -> select MPI type to be MS-MPI and check the box to specify IP address to be 127.0.0.1
      If it doesn't help, try suggestion in here
      /forum/forums/topic/fluent-19-2-not-working/
  • The topic ‘Fluent Problems’ is closed to new replies.
