July 24, 2026 at 10:09 am
cesarj.95plus
SubscriberDear support,
I am using scripts to generate a mesh using the watertight workflowd. My problem is that Fluent assigns the label "ff" to my fluid region when generating the surface mesh but I need to change that since I am having name clashes downstream in the workflow. I have seen on the internet that one solution (at least in Fluent meshing v15) was to generate a material point with a name so when the regions are automatically generatedm the material point name will be assigned. I have generated a material point named fluid_interior (inside the domain) and this is my workflow before generating the surface mesh:
And this right after:
As you can see, Fluent ignores the material point name and generates a volumetric region whose name is "ff" which gives me issues later on when assigning BCs and zone types. How can I change this behaviour and assign the region name before its creation? Thank you in advance!
1343
