July 16, 2024 at 1:58 pm
JMA337
SubscriberHi,
I keep getting the following error when creating a hybrid (tetra+prism) volume mesh for a complex geoemtry. The surface mesh has good max skewness (0.59), good min dihedral (40deg) and there are no free faces, self interceptions or any other issue. I am generating the volume mesh from the linux environment, starting from the surface mesh. Using the auto-mesh command, everything is fine (no stair stepping of the prism layers) until it gets to the pyramid generations stage, where the following error occurs:
Retriangulating adjacent zone int-box-in:875.ÂRemeshing overlapped thread int-box-in:875 ...Deleting overlap on int-box-in:875 ...Improving mesh on int-box-in:875 ...Done.New node zone boundary-node-35148 created for boundary nodes not in current domain (tetrahedral).ÂGenerating Pyramids...ÂCreating pyramidsprism-side-35058 (6944 faces)Â===============Message from the Cortex Process================================ÂCompute processes interrupted. Processing can be resumed.Â==============================================================================Â*** ERROR: multithreading violation ***You are running a multithreaded application butyou set MLX5_SINGLE_THREADED=1. Please unset it.*** ERROR: multithreading violation ***You are running a multithreaded application butyou set MLX5_SINGLE_THREADED=1. Please unset it. The tgrid process could not be started.ÂWarning: An error or interrupt occurred while reading the journal file.Some commands may not have been completed.ÂÂMeshing> Halting due to end of file on input.Transcript Stop Time: 14:46:27, 16 Jul 2024ÂTotal Transcript Time: 4 Minute 47 Second.===========================================================================================
I've not yet had success solving this problem...Any suggestion on what the origin of this error may be?Â
I've tried running the mesh generation on a single node to limit the internode communication, but that did not solve the issue. Reducing the number of prism layers did not make a change either.
July 17, 2024 at 7:12 am
Keyur Kanade
Ansys EmployeeCan you please check if you can generate volume mesh without boundary layer (prisms).
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
July 17, 2024 at 10:13 am
JMA337
SubscriberÂ
Hi Keyur,
Yes, I can confirm the volume mesh is generated fine without prism layers.
Kind Regards,
July 17, 2024 at 12:55 pm
Keyur Kanade
Ansys EmployeeOk. Then it is prism issue. Please make sure that you have selected correct walls to generate prisms. Make sure that prism ends correct at the ends on other walls. Please check following image.Â
Keyur
July 19, 2024 at 9:53 am
JMA337
SubscriberDear Keyur,
Thank you so much. Indeed, there was a typo in my script by which prisms where not being greated on some walls, leading to the segmentation error. That has now been solved.Â
Thank you!
- The topic ‘Fluent Meshing ERROR: multithreading violation’ is closed to new replies.
6625
1311
