TAGGED: fluent-meshing, mesh-generation, surface-meshing
January 19, 2021 at 7:54 am
shadowfax7
SubscriberI've generated an initial mesh of my geometry using Fluent Meshing. However, when I start playing around with min and max size of the surface mesh elements, I suddenly get the following error, which I don't understand:
January 19, 2021 at 11:20 amKeyur Kanade
Ansys EmployeeThis error means you have some free faces in your geometry. So there may be leakage. nPlease go through help manual for more details nMake sure that you are using sufficient sizes and not very coarse sizing. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- The topic ‘Fluent Meshing error –’ is closed to new replies.
4688
1565
1386
1242
